Vaio meets coffee - battery dead?!
hamadasgirl
Hello!
Two months ago my Vaio was flooded by coffe. After some time for drying, now everything works again, except the battery! Although the battery and the external contacts stayed dry. The battery light is blinking and although the battery status changes from time to time, the Vaio doesn´t work wireless.
Does anyone have a tip or maybe experience with such accidents?
I´m thankful for every help.
8 REPLIES 8
apierc1
Personally I would have thought it might be best to take it to somewhere that will take it apart and give it a good clean and can investigate the problem for you.
Andy
hamadasgirl
Hm, yes. That´s what I thought. Unfortunately this is hell expensive...
apierc1
Never had it done, but I'd be guessing about £100ish but if it's a decent machine it's worth it :slight_frown:
rich912
Hi hamadas girl and welcome to the forum.
Do you have home contents insurance, including accidental damage, by any chance? If so you may be covered for the repair.
Go n-éirí an bóthar leat
apierc1
Good idea Rich, but would it then be worth getting more coffee and making the machine defunked and get a new one? :thinking:
rich912
I couldn’t possibly comment on that :wink:
drinkfeckarse
Maybe your contents insurance covers accidents like this?
hamadasgirl
Oh yes, insurance! I had already forgotten about that! Thank you guys! And thanks for the warmly welcome :slight_smile:
