Sound problems with Blu-Ray on a XL202
andy@penkside
Hi, having problems with back ground noise when playing Blu-Ray discs on my VGX-XL202. It comes in the form of a really annoying clicking/tapping sound especially when the film soundtrack is full of noise and music. Have downdloaded updates for WIN DVD -BD and firmware but with no joy. This is an expensive piece of equipment and should not have problems out of the box? Please, any suggestions :cry:
3 REPLIES 3
Blencogo
Hi Andy,
We aren't ignoring you - it just seems that none of the Users here has a solution for you.
You may have to open a case with SONY VAIO-LINK as it sounds like a one-off problem.
:slight_frown:
benyboy
Hi Andy, Having the same problem did you fix it,i've downloaded updates from Vaio Link
slight improvement not complete.
Gope
Hello,
I have exactly the same problem. I just bought the XL-202 one week before and
always if I watch a Blu-ray I have the Sound problems like you described.
Is there a solution in the meanwhile?
Otherwise I will send the device back because it is to expensive if it is not work.
Best regards
Gope
