Sound problems on sony vaio VPCEJ2A9E and itunes problem
jamesmchugh81
I have been having problems with my sony VPCEJ2A9E. Ever since I bought it 2 months ago. When music plays whether in media player itunes or whatever there is frequently distortion. I can only describe it as for example if there is singing they sound electro or robotic?! Also having problems with itunes. The programme is. Ery slow. For example if i delete a track the alert to warn you are you sure you want to delete this is heard but it can take up to a few minutes for the message box to appear. This is just one of the many itunes problems. Not sure if it is a win7 problem? Itunes was never an issue on my old dell vista desktop. Please help!!!! One of the main reasons i got this laptop was to play music at my wedding and the sound is the  only problem i am having! Typical!!
2 REPLIES 2
Torchwood-1
I would simply re-install itunes.
I do not think it is a win7 problem as I have not experienced any problems (so far!).
jamesmchugh81
Have tried that a few times. Appears to not just be itunes though. Same on Movie Maker and other programmes.
