sony Vaio VPCEH only charges battery till 50%
bondldn
Hi there i have a vaio VPCEH3N1E. I recentlly replaced the battery and the laptop only charges it till 50%. How can i get it to charge the battery fully?
Please help!
4 REPLIES 4
rich912
Hi bondldn,
Have you checked whether the battery care function is enabled and set to a max. charge of 50%?
Vaio Control Centre > Power Management > Battery > Advanced Settings.
If the battery care function is not enabled, is this a genuine Sony replacement battery?
Rich
Go n-éirí an bóthar leat
bondldn
Hi Rich
I cant see the battery care function under power management. See image. the replacement battery is not a genuine sony battery.
rich912
You have a number of items missing from Vaio Control Centre menu. Try reinstalling Sony Shared Library followed by a reboot. If this fails to restore all items then reinstall Sony Notebook Utilities followed by Sony Shared Library - again reboot after each install.
I am uncertain as to whether a non Sony battery will support the battery care function.
Rich
bondldn
Thanks Rich
I will try
