Sony Vaio VGC-M1 Recovery discs will not work
springtime
I am trying to reformat my computer. I put the recovery disc 1 in and the recovery procedure started then I received the message recovery complete click ok remove disc machine will restart. I did this and got the message a recent hardware change caused a fault start normal/last known good etc. I tried normal and last known good but still received fault message. I then tried to start in safe mode but got the message windows set up is not complete. can anyone help
Thalamus.
Champion
Hi springtime
Try recovering your Vaio using the hidden HDD recovery partition.
Remove all CD/DVD's from the CD/DVD drive.
Then Restart your Vaio, when you see the Vaio Logo press the F10 key repeatedly.
