sony sdm-n50 monitor
georgeriley
Hey guys
newbie here ive just been given one of these monitors when i plug it in it lights up ok but thats it  as its got its own media engine do i need a driver for it?
Blencogo
Hi georgeriley.
The manual can be downloaded here and the Setup instructions are on Pages 8 to 10.
http://pdf.crse.com/manuals/3868361251.pdf
There are no downloads available on the Support Page here so I don't think drivers are needed: -
http://www.sony.co.uk/support/en/product/SDM-N50
:thinking:
3 REPLIES 3
nikkilim
Hi George. Usually, you don't need a driver for that since Windows will automatically recognize it and use a generic display driver.
But if you want optimum performance, you can install the specific driver itself. Take a look at Device Manager and yiou should be able to see that all drivers are working fine. https://imagicon.info/cat/12-13/vmware_happy.gif
georgeriley
mmmm thanks can you tell me why i have no picture on screen it lights up ok but thats it
Blencogo
Hi georgeriley.
:thinking:
