Problems with my WIFI?
James-Whitehouse
I was recently browsing the internet on my laptop and then it just dropped the connection on both Ethernet and WIFI which has completely stopped working until i restart my computer and it works for about 10-15 minutes then disconnects once again.
Also my Ethernet cable connection drops occasionally for some reason saying "The default gateway is not available". I dont know if this is a driver related issue?
WIFI Driver Atheros AR9285
Ethernet Driver Realtek 7.17.304.2010
Much appreciated
Thanks.
Message was edited by: James-Whitehouse
profile.country.ro_RO.title
ruxmanea
Hi James,
Is not stated what OS you are using, however, maybe you check the Microsoft/Windows forums.
Here is a thread that kind of looks like a possible answer to your problem
http://windows7forums.com/windows-7-networking/54821-default-gateway-not-available.html
Good luck!
Ruxandra
