I am unable to burn my Verbatim DVD+RW 8x .
It works sometimes, but most times I get "power calibration error" or "unknown burner error"
This just happens with this media. And maximum speed is set to 3.3x
Isn't the burner supposed to support 8x RW media?
All other "slower" media I've tried has worked.
Does anyone know if there is a firmware upgrade for this unit?
Hi multimax,
What's the brand model of your unit?
What's the SW you are using to burn your DVD?
