memory stick PRO
Okkie
memory stick PRO
Dear all.
finally I have bought a digital camera from sony, which uses a memory stick PRO.
Also I use my Vaio sony notebook: FRG-FR415M which has a magicgate for this memory stick.
When I put the stick in the gate, nothing happens.
In the beginning of using my notebook, something went wrong, and the software was re-installed.
Probably I lost some drivers in that process.
on ftp://ftp.vaio-link.com/ I can find drivers for memorystick but which one do I need.
Extra problem: my keyboard is installed as IBM and not as sony. This is slightly difficult because @ and " are switched etc.
Which driver do I need to correct this.
with kind regards.
Marjon Kok
The Netherlands.
5 REPLIES 5
TygerTyger
Not sure about the keyboard, but the Memory Stick driver will be in your C:\Drivers folder on your computer. If it is not, then you can download the Original Drivers Package from http://www.vaio-link.com which contains the Memory Stick driver.
Just as an aside, Magicgate is actually a copyprotection scheme for the memory sticks. The slot on your computer is just known as a Memory Stick slot, not a gate.
profile.country.de_DE.title
seb21__
LOL, that is surprisingly. I have PCG-FR315S and I have no problems to using a MemoryStickPro Duo.
That thing with the keyboard seems to be normal. Mines is a Microsoft Natural Keyboard (PS2).LOL The keyboard type is IBM enhanced. I think the reason for that is the keyboard layout or anything.
I wouldn't worry about that. A lot of your VAIO is not from Sony.:smileytongue:
rich912
To configure your keyboard open Control Panel > Regional and Language Options > Languages > Details¿ , select Add and choose your input language. Check the Keyboard layout/IME box, and select United Kingdom (other keyboard layouts may also reverse @ and ¿). Click OK and in the Settings Tab make sure that `Your Language - United Kingdom¿ is selected as the default input language. You should see that Keyboard is noted as United Kingdom in the installed services box.
Go n-éirí an bóthar leat
Okkie
Thanks for the info. I found the drivers, but big question:
what is the name.
Also a lot of drivers are also at the ftp site, but still, I dont know the name.
I am not a computer wizzard. Only switch the stuff on/off.
:smileynerd:
The original drivers package I did not found it on the viao site.
Please, do you have more info for me
marjon
rich912
The Preinstalled Drivers for the FR415M can be downloaded from here.
The Setup Information file is named SonyWBMS.inf.
