Hi all,
I've got a problem where Nero errors at 94% each time I try to burn a CD-R. I've tried Nero 7 & Nero 8, as well as Deepburner, and the burn always fails at 94%. Interestingly, a CD-RW burning the same data finishes fine. I've got the Matshita UJ-850s drive, and the Nero error log is as follows:
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.0.3.0
Internal Version: 8, 0, 3, 0
Recorder:Version: 1.20 - HA 1 TA 0 - 8.0.3.0
Adapter driver:HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM:Version: 1.20 - HA 1 TA 0 - 8.0.3.0
Adapter driver:HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : IL4075I BZG481C 2.0B al8kcqj1 Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-850S E: CdRom0
IL4075I BZG481C G: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1021MB (1046080kB)
Free physical memory: 396MB (405892kB)
Memory in use : 61 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.9.2007
Audio CD
15:00:20#1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
15:00:20#2 CDADOC -1 File Cdadoc.cpp, Line 1588
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:43.42, Pause frames: 150, Filters: 0, Name: '01 Dave Spoon - Latronica.mp3'.
Track 02: Length: 03:29.08, Pause frames: 000, Filters: 0, Name: '02 Alan Braxe & Kris Menace - Lumberjack.mp3'.
Track 03: Length: 05:09.02, Pause frames: 000, Filters: 0, Name: '03 Tamara's World - Trampoline (Cedric Gervais Mix).mp3'.
Track 04: Length: 04:00.08, Pause frames: 000, Filters: 0, Name: '04 Mekkah ft Stephen Granville - Race of Survival (Roman Curtis Mix).mp3'.
Track 05: Length: 06:00.05, Pause frames: 000, Filters: 0, Name: '05 Ijah - Nitelife (Seamus Haji Big Love Mix).mp3'.
Track 06: Length: 05:42.70, Pause frames: 000, Filters: 0, Name: '06 Blue Ray Ft Jimmy Somerville - You & Me.mp3'.
Track 07: Length: 08:00.39, Pause frames: 000, Filters: 0, Name: '07 Just Jack - Writers Block (Seamus Haji Big Love Mix).mp3'.
Track 08: Length: 05:23.08, Pause frames: 000, Filters: 0, Name: '08 Mr Hudson & The Library - Picture Of You (Seamus Haji Mix).mp3'.
Track 09: Length: 05:31.19, Pause frames: 000, Filters: 0, Name: '09 Roisin Murphy - Overpowered (Seamus Haji Mix).mp3'.
Track 10: Length: 05:30.06, Pause frames: 000, Filters: 0, Name: '10 Jorgensen - Untitled.mp3'.
Track 11: Length: 03:36.20, Pause frames: 000, Filters: 0, Name: '11 Haji & Emanuel Ft Robert Owens - If (Ran Shani Mix).mp3'.
Track 12: Length: 04:46.18, Pause frames: 000, Filters: 0, Name: '12 K3 Ft Alice Lascelles - Play To Win (Danny Freakazoid MIx).mp3'.
Track 13: Length: 05:46.32, Pause frames: 000, Filters: 0, Name: '13 Dirty South & Paul Harris - Better Day (TV Rock Remix).mp3'.
Track 14: Length: 04:23.11, Pause frames: 000, Filters: 0, Name: '14 Kurd Maverick - Let's Work.mp3'.
Track 15: Length: 04:36.59, Pause frames: 000, Filters: 0, Name: '15 Bob Sinclar - Everybody's Movin (Eddie Thoneick & Kurd Maverick Mix).mp3'.
Total size: 77:40.47
15:00:20#3 Text 0 File Burncd.cpp, Line 3202
Buffer underrun protection activated
15:00:20#4 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:00:20#5 Text 0 File Burncd.cpp, Line 3520
Turn on Disc-At-Once, using CD-R/RW media
15:00:20#6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 349396 ( 77:40.46)
15:00:20#7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
15:00:20#8 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: MATSHITA DVD-RAM UJ-850S;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
15:00:20#9 Text 0 File DlgWaitCD.cpp, Line 493
15:00:20#10 Text 0 File ThreadedTransferInterface.cpp, Line 795
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (01 Dave Spoon - Latronica.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 25767 (25767) = #25767/5:43.42
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25767 blocks [E: MATSHITA DVD-RAM UJ-850S]
1: TRM_AUDIO_NOPRE (02 Alan Braxe & Kris Menace - Lumberjack.mp3)
2 indices, index0 (0) not provided
original disc pos #0 + 15683 (15683) = #15683/3:29.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15683 blocks [E: MATSHITA DVD-RAM UJ-850S]
2: TRM_AUDIO_NOPRE (03 Tamara's World - Trampoline (Cedric Gervais Mix).mp3)
original disc pos #0 + 23177 (23177) = #23177/5:9.2
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23177 blocks [E: MATSHITA DVD-RAM UJ-850S]
3: TRM_AUDIO_NOPRE (04 Mekkah ft Stephen Granville - Race of Survival (Roman Curtis Mix).mp3)
original disc pos #0 + 18008 (18008) = #18008/4:0.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18008 blocks [E: MATSHITA DVD-RAM UJ-850S]
4: TRM_AUDIO_NOPRE (05 Ijah - Nitelife (Seamus Haji Big Love Mix).mp3)
original disc pos #0 + 27005 (27005) = #27005/6:0.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27005 blocks [E: MATSHITA DVD-RAM UJ-850S]
5: TRM_AUDIO_NOPRE (06 Blue Ray Ft Jimmy Somerville - You & Me.mp3)
original disc pos #0 + 25720 (25720) = #25720/5:42.70
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25720 blocks [E: MATSHITA DVD-RAM UJ-850S]
6: TRM_AUDIO_NOPRE (07 Just Jack - Writers Block (Seamus Haji Big Love Mix).mp3)
original disc pos #0 + 36039 (36039) = #36039/8:0.39
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 36039 blocks [E: MATSHITA DVD-RAM UJ-850S]
7: TRM_AUDIO_NOPRE (08 Mr Hudson & The Library - Picture Of You (Seamus Haji Mix).mp3)
original disc pos #0 + 24233 (24233) = #24233/5:23.8
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24233 blocks [E: MATSHITA DVD-RAM UJ-850S]
8: TRM_AUDIO_NOPRE (09 Roisin Murphy - Overpowered (Seamus Haji Mix).mp3)
original disc pos #0 + 24844 (24844) = #24844/5:31.19
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24844 blocks [E: MATSHITA DVD-RAM UJ-850S]
9: TRM_AUDIO_NOPRE (10 Jorgensen - Untitled.mp3)
original disc pos #0 + 24756 (24756) = #24756/5:30.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24756 blocks [E: MATSHITA DVD-RAM UJ-850S]
10: TRM_AUDIO_NOPRE (11 Haji & Emanuel Ft Robert Owens - If (Ran Shani Mix).mp3)
original disc pos #0 + 16220 (16220) = #16220/3:36.20
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16220 blocks [E: MATSHITA DVD-RAM UJ-850S]
11: TRM_AUDIO_NOPRE (12 K3 Ft Alice Lascelles - Play To Win (Danny Freakazoid MIx).mp3)
original disc pos #0 + 21468 (21468) = #21468/4:46.18
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21468 blocks [E: MATSHITA DVD-RAM UJ-850S]
12: TRM_AUDIO_NOPRE (13 Dirty South & Paul Harris - Better Day (TV Rock Remix).mp3)
original disc pos #0 + 25982 (25982) = #25982/5:46.32
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25982 blocks [E: MATSHITA DVD-RAM UJ-850S]
13: TRM_AUDIO_NOPRE (14 Kurd Maverick - Let's Work.mp3)
original disc pos #0 + 19736 (19736) = #19736/4:23.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19736 blocks [E: MATSHITA DVD-RAM UJ-850S]
14: TRM_AUDIO_NOPRE (15 Bob Sinclar - Everybody's Movin (Eddie Thoneick & Kurd Maverick Mix).mp3)
original disc pos #0 + 20759 (20759) = #20759/4:36.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20759 blocks [E: MATSHITA DVD-RAM UJ-850S]
15:00:20#11 Text 0 File ThreadedTransferInterface.cpp, Line 997
Prepare [E: MATSHITA DVD-RAM UJ-850S] for write in CUE-sheet-DAO
DAO infos:
MCN: "†††††† Ā༁"
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 15: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 60956784, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 60956784 60956784 97843200, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 97843200 97843200 152355504, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 152355504 152355504 194710320, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 194710320 194710320 258226080, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 258226080 258226080 318719520, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 318719520 318719520 403483248, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 403483248 403483248 460479264, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 460479264 460479264 518912352, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 518912352 518912352 577138464, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 577138464 577138464 615287904, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 615287904 615287904 665780640, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 665780640 665780640 726890304, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 726890304 726890304 773309376, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 773309376 773309376 822134544, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 0 | 0 | 0x00
0 | 1 | 1 | 0x21 | 25767 | 0 | 0x00
25767 | 2 | 0 | 0x21 | 0 | 0 | 0x00
25767 | 2 | 1 | 0x21 | 15683 | 25767 | 0x00
41450 | 3 | 0 | 0x21 | 0 | 0 | 0x00
41450 | 3 | 1 | 0x21 | 23177 | 41450 | 0x00
64627 | 4 | 0 | 0x21 | 0 | 0 | 0x00
64627 | 4 | 1 | 0x21 | 18008 | 64627 | 0x00
82635 | 5 | 0 | 0x21 | 0 | 0 | 0x00
82635 | 5 | 1 | 0x21 | 27005 | 82635 | 0x00
109640 | 6 | 0 | 0x21 | 0 | 0 | 0x00
109640 | 6 | 1 | 0x21 | 25720 | 109640 | 0x00
135360 | 7 | 0 | 0x21 | 0 | 0 | 0x00
135360 | 7 | 1 | 0x21 | 36039 | 135360 | 0x00
171399 | 8 | 0 | 0x21 | 0 | 0 | 0x00
171399 | 8 | 1 | 0x21 | 24233 | 171399 | 0x00
195632 | 9 | 0 | 0x21 | 0 | 0 | 0x00
195632 | 9 | 1 | 0x21 | 24844 | 195632 | 0x00
220476 | 10 | 0 | 0x21 | 0 | 0 | 0x00
220476 | 10 | 1 | 0x21 | 24756 | 220476 | 0x00
245232 | 11 | 0 | 0x21 | 0 | 0 | 0x00
245232 | 11 | 1 | 0x21 | 16220 | 245232 | 0x00
261452 | 12 | 0 | 0x21 | 0 | 0 | 0x00
261452 | 12 | 1 | 0x21 | 21468 | 261452 | 0x00
282920 | 13 | 0 | 0x21 | 0 | 0 | 0x00
282920 | 13 | 1 | 0x21 | 25982 | 282920 | 0x00
308902 | 14 | 0 | 0x21 | 0 | 0 | 0x00
308902 | 14 | 1 | 0x21 | 19736 | 308902 | 0x00
328638 | 15 | 0 | 0x21 | 0 | 0 | 0x00
328638 | 15 | 1 | 0x21 | 20759 | 328638 | 0x00
349397 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
15:00:20#12 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
15:00:20#13 Text 0 File Burncd.cpp, Line 4306
Caching options: cache CDRom or Network-No, small files-No (<64KB)
15:00:20#14 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 24x (3,600 KB/s)
15:00:20#15 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:00:20#16 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #25767
15:00:20#17 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #41450
15:00:20#18 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #64627
15:00:20#19 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #82635
15:00:20#20 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #109640
15:00:20#21 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #135360
15:00:20#22 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #171399
15:00:20#23 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #195632
15:00:20#24 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #220476
15:00:20#25 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #245232
15:00:20#26 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #261452
15:00:20#27 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #282920
15:00:20#28 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #308902
15:00:20#29 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #328638
15:00:20#30 Text 0 File MMC.cpp, Line 17734
StartDAO : CD-Text - On
15:00:20#31 Text 0 File MMC.cpp, Line 22418
Set BUFE: Buffer underrun protection -> ON
15:00:20#32 Text 0 File MMC.cpp, Line 17964
CueData, Len=144
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 01 00 00 05 2d 2a
21 03 01 00 00 09 0e 32
21 04 01 00 00 0e 17 34
21 05 01 00 00 12 17 3c
21 06 01 00 00 18 17 41
21 07 01 00 00 1e 06 3c
21 08 01 00 00 26 07 18
21 09 01 00 00 2b 1e 20
21 0a 01 00 00 31 01 33
21 0b 01 00 00 36 1f 39
21 0c 01 00 00 3a 08 02
21 0d 01 00 00 3e 36 14
21 0e 01 00 00 44 28 34
21 0f 01 00 00 49 03 3f
01 aa 01 01 00 4d 28 2f
15:00:20#33 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
15:05:52#34 SPTI -1135 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 04 B9 D0 00 00 1B 00 00 00
Sense Area: 0xF1 00 03 00 04 B7 53 0A 00 2B 00 00 0C
Buffer x0b7f8040: Len xf810
0xF5 10 8A F7 59 01 92 E6 C1 F4 BC DF 65 E9 EE DB
0xC2 E1 C3 D7 75 DF FD D6 48 DB 4B D4 13 DD 07 D8
0x5A E1 48 E2 00 E0 97 E8 6C E3 41 EF EF EB EF F6
15:05:52#35 CDR -1135 File Writer.cpp, Line 312
Write error
15:05:52#36 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 24x (3,600 KB/s)
15:05:52#37 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
15:05:52#38 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
15:05:52#39 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
15:05:57#40 Text 0 File Cdrdrv.cpp, Line 11159
DriveLocker: UnLockVolume completed
15:05:57#41 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
