Major network and wireless adapter issues
I have sony vaio laptop according to the vaio smart network my wireless network is on and the green led light is on for wireless at the edge. I can't seem to connect to any wifi though as when I do connect dial up and broadband connection comes up. By the way on the vaio smart network tab it says 'connect:disconnected'. In terms of my control panel it shows no signs of wireless capability yet it there is a green wireless light but it immediately displays to connect with a Ethernet cable which is obviously not the one I prefer and comfortably use. I'm in this issue for few days now. Any sort of help from you guys will be appreciated sincerely. Thank You.
0 REPLIES 0
