Hi again
I have just setup my wireless router with my SZ and all is well on normal start-up i.e. once logged on the connection from wireless adapter to router is made and I can access internet. The problem occurs when I close the lid and the laptop goes into Sleep mode - when I open the lid the wireless connection is not automatically made and I can manually connect as the wireless netwrk does not appear on the list and even when refreshing the list it still does not appear, the only way I can get a connection is to restart the laptop. Any ideas?!
g
Have you tried this Microsoft Hotfix?
KB933872
I'm not sure if it will work but it must be worth a try!!
KB933872
