Laptop won't boot up after loss of power.
hannon555
My laptop just turned off, not like a propere shut down or crash but total loss of power and now it won't turn on.
It trys to turn on and then stops after 2 seconds and doesnt get to the vaio logo screen.
The laptop is a vaio vgn-fw31m.
I know probable might not be able to be fixed without a repair but just wondering if anyone has heard of this problem or had it before so know if its motherboard, circuit or shorting problem so no general ball park money wise of fixing it.
Any help much appericated
Kintesh
try starting your laptop on battery only. without power supp.   if it turns on, plug in  power supp. if the laptop goes off as soon as you plg in power that means you need to send it for repair. th problem is on the motherboard.
