Laptop Battery
beeblec
Laptop Battery
I Have a Vaio Type PCG 4L1M fitted with battery part number VGP-BP11. I have searched both the internet and sony parts site unable to find a replacement as searches come up with zero.
Can Anyone help with this problem
Beeblec
Blencogo
This looks like a genuine Sony battery: -
http://www.okobe.co.uk/ws/product/Sony+VGP+BPL11+Lithium+Ion+Laptop+Battery+for+Sony+VAIO+VGN+TZ+Ser...
If you have a problem finding one in stock, you could try Vaio Support to see if they still have some in stock and will sell you one.
Try Google using your correct model type on the screen surround - something like VGN-TZ21XN.  The full battery code is VGP-BPL11
:thinking:
