Help - Vaio Recovery Utility
profile.country.it_IT.title
stepelle4
Hi all,
I wanna recover my VGN-FZ18M with the recovery partition but in the package I've downloaded from Vaio support I couldn't find the recovery tool... can anyone tell me where I can find it?
Thanks a lot...
Stefano
5 REPLIES 5
Thalamus.
Champion
Hi Stefano,
You can either go to Start > Vaio Recovery Tool > Vaio Recovery Utility to recover your Vaio..
or
Start your Vaio when you see the Vaio logo press F10 repeatedly this normally would also start the recovery process..
stepelle4
Hi Thalamus, thanks for your answer, but I've messed up my pc with a fresh new installation of Vista and I have no more the recovery tool and I cannot find in the package downloadable...
Thalamus.
Champion
Hi
Do you still have the recovery partition..?
If so try this, Start your Vaio when you see the Vaio logo press F10 repeatedly this normally would also start the recovery process..
If that does not work then you can contact Vaio-Link to purchase a new set of recovery DVD's..:smileysad:
stepelle4
Thanks Thalamus, yes, with F10 during boot I've found what I needed.
ciao!
Thalamus.
Champion
:cool: You're welcome.. :slight_smile:
