Help, unable to open my usb stick on my sony!!!!!
Please can someone help!!! I have a new sonyviao computer and I have two usb stick with alot of work on I wanted to transfer to my new comp. One worked fine and the other one will not open on the comp. A message comes up and saying that i need to format it, so i follow the instructions and then when i start the format process it then says that to do this will erase all the data on the drive.  when i press cancel it tells me to check that the files are not read onlyfiles and i cant find anywhere where it shows that. Please can someone help me as i deperately need to get into this usb.
Thanks,
stacey
0 REPLIES 0
