I know this is a very new laptop, but have they made a driver for the motioneye camera for it yet? do you definately need a driver to get the camera to work? When i first turned on the camera it worked and i was able to take pictures etc. but now it isnt working. Has anybody else had the same problem, and what is the solution? Thanks
Hi Katie,
I had the same problem with my VGN-FE41Z, worked fine until one day the operating system simply didn´t recognize it! I tried reinstalling the drivers, but this didn´t work. I only regained the camera after doing a full rebuild from the restore particion, due to other issues with Windows vista!!! I assume you have checked that the vaio camera utility,is still set to the motion eye and hasn´t simply suffered a change! Sorry I can´t be more help.
Shaun.
