fz11z
it didnt startup (first time it happened) 😞
well it seems as though my cam doesnt work now 😞
woe is me!
Hi Shaggy,
Does it work with Skype? Can you configure it in the Skype -> Tools -> Options -> Video Settings?
What happens when you run 'Vaio Camera Capture Utility' from the Start Menu?
Is the Camera installed properly? Look in Control Panel -> Device Manager and expand "Imaging Devices". Does the Sony Camera show up there as being installed?
You are not alone - several members have camera problems with Vista.
CAM sometimes doesn't work. Vista says its been used by another program. After reboot it's ok. For a expensive laptop i am not amused. I hope Sony or MS comes with a solution.
Hi Wendy_Soren,
welcome to Club Vaio..
Does the post in this thread offer a solution..?
