Display problem
stehart14
Display problem
Hi there. I have a Sony Vaio VPCJ11M1E and  have a display problem. Graphics are Nvidia GeForce 310M GPU. Monitor showing in Device manager as "Digital Flat Panel (1920x1080 60HZ)"Window version - Windows 8 Consumer Preview. Since I installed Windows 8 I am experiencing some minor display problems, from the information above can anyone advise me how to correct these?Thanks Steve
Message was edited by: stehart14
rich912
Hi Steve,
I have no knowledge of Win 8 but after installing Windows 8 have you tried installing the original NVIDIA graphics driver?
http://www.sony.co.uk/support/en/product/VPCJ11M1E_B/updates
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rich912
Hi Steve,
Rich
nikkilim
Hi. You can possibly go to Nvidia site and server for the driver with your specific graphics. Just download it and install. You should be all set after that. http://imagicon.info/cat/12-13/vmware_happy.gif
Message was edited by: nikkilim
nikkilim
Double posted. Apologies. I cant find the option to delete, I just edited this.
celavey
Windows 8 is a new OS and it is pretty much certain that you may encounter minor difficulties dealing with software and programs you already. It is one of the things you should be aware of especially when upgrading to a new OS.
