Cannot get my Vaio Laptop to work with Panasonic TV using VGA to HDMI Converter box
garyenl
I have an old Vaio laptop, VGN-N38E/W and I am trying to get it to connect to the HD TV in order that I can watch IPlayer etc on larger screen. So far I have:
  • Bought a VGA to HDMI converter
  • Connected the Laptop to the converter using the VGA cable
  • Connected the TV to the converter using the HDMI cable
  • Plugged in the audio cable
  • I have gone into the control panel and set up the second monitor, as 'extended display' and setup the display resolution.
  • I have tried to link the Laptop to the TV but all I get is a blank screen on the TV. I have tried pressing the Fn and F7 keys together and separately but it has not made a difference.
Any help would be appreciated, as every thing I have read states that doing all of the above should work!!
Thanks in advance
2 REPLIES 2
Blencogo
Hi garyenl and welcome.
Can you give us a link to the particular VGA to HDMI converter you are using?
:thinking:
garyenl
Hi
Thanks for responding - this is the converter box I am trying to get working.
http://www.ebay.co.uk/itm/1080P-HD-Mini-VGA-to-HDMI-3-5mm-Audio-Video-Converter-Adapter-PC-Box-DLP-H...
Any help appreciated
Gary
