Battery
co2laser
Battery
My VGN-C2S is showing the battery is not detected I have removed and refitted it but it is still the same. Is this a known problem or is the battery shot.
3 REPLIES 3
rich912
Hi co2laser,
On my one and only experience of this the battery was ‘shot’.
To eliminate other problems you could try and borrow a battery or call in to a Sony Centre and ask nicely if you could try one from a compatible machine...
Go n-éirí an bóthar leat
co2laser
Thank for the advice I will hunt down a battery. I don't know if it's important but mine has never really be run off the battery.
rich912
Neither had the one that failed on me :slight_frown:
