Battery on FZ11Z
Verynewtovaio
Battery on FZ11Z
Hello fellow users.
I have recently purchased a FZ11Z notebook. Does anyone know how long the bettery should last on this once fully charged?
I have fully charged the battery
Booted on AC Adapter
Disabled all start up items, including screensaver etc
Not even moved the mouse
The battery only lasts 90 mins.
Is this a faulty battery or a feature of this expensive laptop?
If I surf the net on then a full battery will last less than an hour.
I welcome your feedback.
Regards
el_cardi
I think a battery only reaches it's full capacity after a couple of load/emptying sequences. How about your completely empty and load for about 5 time and then check again ?
Succes,
Luc
