Battery icon
guvey101
Battery icon
Hi, i have a VGN FE-41E with windows vista home premimum. Just wanted to know if you could change the battery icon in the system tray from a percentage to the number of hours left, as its a bit more useful.
Thanks in advance
Thalamus.
Champion
Hi guvey101
It is normal for Sony Vaio's to only display the % remaining..
There are applications available, not sure whether they'll run on Vista though, something like battery mate, that can predict the time available. I can't say how accurate they would be though as I have never used one..
