Battery Care Function Not Holding After Reboot
RosieBoy
Hello
The Battery Care Function on my VPCY11MIE had been working fine for years. I had it set to 80% charge.
Recently however, the setting is not saving between reboots, ie after I restart my laptop the Battery Care Function is not set and I have to go in a select it again. Once set, it works perfectly. Next time I start my laptop the Battery Care Function is not set. This is becoming very annoying.
I have tried looking to see where this setting value may be store, but with no luck.
Any advised would be appreciated.
0 REPLIES 0
