Hi, I have a KDL-24W605A in the kitchen and I want to attached it to the wall under the kitchen units. I have half of the original wall bracket (the bit that attaches to the TV - Like a handle) but I'm missing the white wall mounting part. I've lost them over this last few years. Does anyone know please where I can get these brackets from. Or preferably any suggestions on wall brackets that have been made to fit. Thanks
Hi – I'm pretty sure these are still available from aftermarket suppliers, reasonably priced.
This looks like it may be the right one?
Mick
Hi Mick, thanks for the response. I did as you suggested and got loads of hits for generic wall mount kits. Which of course do not fit the 24" W6. Ebay have a couple of Sony original brackets (part no 44688301) but they come from Greece and had a delivery of 2 weeks ish!. So once I found the part number I searched for it again and found that Stuff-UK.net sell it for a reasonable £21.08. Delivery is 5 days or 3days or next day all at a cost starting from roughly £5. The link you found was the same bracket but when I proceeded to the purchase basket it came up with a delivery charge of over £12. which I thought was a little too much. So ordered from Stuff-UK at a reasonable £28 for three days delivery.
Thanks again
Alan
Mick
Thanks again
Alan
