Hi, I have recently bought Sony Bravia KDL 32EX340 and I like it very much, but when I plug in my USB flash drive (I actually tried several USB flash drives) I get the "USB is not supported" line. I made sure that the files are in the right format (avi,wmv,etc.). Can you please explain where my mistake is? Thank you in advance :
i have the same problem here with the same tv, i have an hp usb v195b 16 gb, and the the tv won't recognize ntfs format, just fat32, although in the manual is says it also supports ntfs and i don't want to use fat32 because of the 4gb limitation, someone find a solution, please!
