Hi
Recently connected a new AV amp to my KDL-40EX703 but only using my Tannoy hi-fi speakers at the moment. When viewing TV with the AV sound on I am getting a split second interruption in output from the AV with most times a slight crack sound (not every time) as if it was switching interference from somewhere (I don't think it is as I have checked wether something is doing this) also the speaker indicator on the display flashes off at the same time. It also does it when internet streaming but not when using the blueray player. Internet is connected with network plugs and cables are HDMI and digital optical. Can't figure out if this is a problem with the TV or the amp. Speakers are bi-wired and amp is Yamaha which is set up for bi-wiring. Anyone got any ideas as I am completely foxed?
