Sony KDL-50-W82 Remote Control - Mind of it's own
GregStagg
G'day
Recently been having issues with the remote control for my TV (as stated in the title). Intermittently, although it is becoming more regular, I press any button on the remote and it will act as if the volume down button is being constantly pressed... Any ideas how to fix / what I'm doing wrong?
I have a Harmon Kardon soundbar connected via HDMI TV (ARC slot though this doesn't seem to work). The TV remote also controls the soundbar after programming the soundbar. The remote shows up on the TV saying 'System volume -' and also turns the soundbar down, this makes me think that's it's a remote control fault. Possibly something to do with batteries?! They have the powercheck which shows there is charge in the battery.
Greg
Tags (2)
Anonymous
Hi there
If in doubt, replace batteries is the first thing to try.
In regards to other issues, have a look at each of the buttons on the remote control and ensure that none are 'stuck' down.
Im not sure on your issue for the HK Soundbar.  This seems like normal operation to me (assuming the HK soundbar is compatible with HDMI-CEC functions).
2 REPLIES 2
Anonymous
Hi there
GregStagg
Struggling to find my question to reply - it seems to be have fixed the problem... Thanks Q!
