kdl-40hx853 Power Indicator
Ali-cain
Hello,
I am very pleased with my recent purchase of a kdl-40hx853.
I'd like to disable the Power Indicator LED on the front on the TV, I cant see the option anywhere, does anybody know if that is possible or how to request it as a feature?
Many thanks,
Alastair.
Bravia55HX
Hi again,
no you cannot disable this power indicator im afraid.
3 REPLIES 3
Bravia55HX
if you mean the red standby light then theres a on/off button on the right hand side of the set.
Ali-cain
Thank you for the reply, but it is the green power indicator when the TV is on that I would like to disable.
I can tell when the TV is on and I think the border of the TV would look cleaner without the LED on.
Regards,
Alastair.
Bravia55HX
Hi again,
