? KDL-40EX713 wired connection?
smokingman
Hi to you all
I have just purchaced the above TV, the problem is that it will not connect to the wired network. The sony DVD player BDP-S370 will connect with the same cable etc no problem and display this through the TV. THe TV reconises that it is plugged into a cable
the following is what is displayed:
     Cable Connection        OK
     local Access               Failed
     Internet Access           Failed
Can anyone help?
THanks
John
5 REPLIES 5
wetsleet
Have you tried restarting the router? Also check there are no rules/filters in the router which would block the TV's IP address or MAC address. Look in the router and check it has issued an IP address to the TV.
smokingman
IP address isued for TV 192.168.x.x and a MAC address of tv is listed but no host name. All other devices inc DVD player have host name, ip address and MAC address
DVD player ip is with in range of all devices, infact it is two up from tv but within my allocated range of 10 ip addresses.
router reset. may change the fly lead!!!!!!!!!!!!!!!
hope this helps
Catmambo
Your router is blocking it somehow as they are simple plug and play devices. Maybe try tweaking some router settings, but to be honest, its going to be very hard to troubleshoot as every router is different.
wetsleet
the obvious place to look in the router are:
MAC Address filtering (just spotted my router has two of these, wired and wireless)
IP Client Filtering
In my Belkin router they look like this, as attached
Message was edited by: wetsleet
smokingman
Problem solved!!!!!!
Flashed a update to the router it was only .2 of a rev out but it made a differance.
All now works.
