KDL 40EX403 AV2 Output Sets a signal to output from AV2.
banchang
I want to output from scart what is currently being viewed on screen
Per Sony i-Manual Help :
AV2 Output
Select “TV” to output TV broadcasts, and “AV1” or “AV3” to output signals from equipment connected to each jack (socket). Select “Auto” to output what is currently being viewed on the screen (only available for TV broadcasts, and SCART or composite input).
When I see AV2 on the crossbar menu, the word TV is in a grey box in bottom right hand of the screen (see pic below). Per above guidance, how do I change from TV to Auto ? What menu keystrokes do I use ?IMG_7062.PNG
Anonymous
Hi there
All the ports on your TV except the 'Digital Audio Out' are INPUTS only.  This includes the SCART sockets.
Basically, you OUTPUT from a device and INPUT it to the TV
Its really the same answer to your other post:
https://community.sony.co.uk/t5/televisions/i-m-an-amateur-please-help/m-p/2144844#M42322
