is this Xperia Ultra t2 dual BLE? BLuetooth low energy? I mean is it included or should I update something?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Yes, the Xperia T2 Ultra Dual supports BLE. You do not have to install any app to enable this.
I would like to know if T2 Ultra support BLE.
Joseph
Yes, both T2 Ultra and T2 Ultra Dual supports BLE.
