Xperia T2 Ultra - work with Verizon?
loup18
Hi, Will the Xperia T2 Ultra work with Verizon?  I'm OK if the answer is to reflsh it.
Really like my T2 but can't get a stright answer.
thx in advance,
Luka
Tags (2)
Anytime, you should be able to get your money back at BestBuy, perhaps you might be interested on the Xperia Z3V that will work with Verizon
8 REPLIES 8
Thommo
This all depends on what version number of the T2 you have and whether or not the version you have is compatible with their network band and also if your device in network unlocked and if you are travelling then is your device country unlocked
Verizon and Sprint are CDMA networks not GSM, it won't work
Thommo
You learn something new everyday
True that, now the question is, the Z3v its a CDMA phone but it requires a SIM card to work with LTE, so I wonder if its possible to use only verizon's LTE?
loup18
Thanks Thommo & Uliwooly for your replies – sounds like due to Verizon’s network being CDMA, and the phone being GSM, I have my answer that I can’t get voice to work on the Verizon switch….. did I get that right?
To address Thommo’s questions:
1. This all depends on what version number of the T2 you have – D5316
2.  Whether or not the version you have is compatible with their network band – Verizon is CDMA & Sony is GSM phone
3. If your device in network unlocked – yes (bought at Best Buy; regular $300 for $200)
4. If you are travelling – never
Thanks in advance!
loup18
Yes, Uliwooly, will look into the z3v!
Harassedcustome
Hello m Saksham bhatnagar from ghaziabad up I have purchased my T2 ultra from vijay sales but the ph is not working from the 1St day now m so much harassed that no option is available apart from consumer court
