This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
After an upgrade I always perform a system repair to iron out issues of this nature - See below
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Re-install lollipop with PCC and check again
Bridge (for Mac)
Hi Ksharma,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
How long have you had the software? if you have only had it for a short period of time, you will need to give the device more time to optimize based on the way you use the device, this can take a week or so.
I hope this helps.
When i connect a USB Flashdisk, the application which stored to external SDCard showing error. See in picture bellow
One more to list.
When I use the volume to adjust the phone ringtone volume.
Sometimes it doesn't play the volume adjustment sound.
Did someone else got this problem ?
Some times when I open the recent apps., the widget all gone.
And I have to add all the widget again.
Happen already a few times.
Already repair the phone with PCC.
Could you please send me a private message with the IMEI and build number of your phone?
We got this feedback on another model and the information i got when i forwarded this is that it has been designed to not give a beep for every press if you press it several times in a row.
@Rickard
Okay then I think I already get how it works.
how about the recent apps widget ?
is it known problem or what then ?., been re- adding it several times and keep missing somehow after a certain time.
I haven't seen that in my phone but renownep reported it earlier in this thread and it's been forwarded as feedback.
