Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
@Alexandre_Marques
Don't cross post, if PCC doesn't solve the issue, contact your local Xperia Care
PC Companion (PCC)
Bridge (for Mac)
http://support.sonymobile.com/global-en/contactUs/
farie
Hello everyone.
I have these following issues on my Xperia T2 Ultra (D5303 4G) running Android 5.0.2:
Sudden restarts
Speaker distortion
Battery drain
Lag (phone call and bluetooth transfers)
Hang (during bluetooth playback)
Graphical glitches (once)
Missing applications (restart/disconnecting usb from pc)
Incompatible Headset (might be on purpose)
Santanu1974
Dear Sony Team,
I am using Sony mobile from resonably long time and one day the software update option popup and shows Update available to Lollipop, hence I have done the update but very unfortunate things happened after the update the followings. Also very important information my phone is around 10 months old.
1. Battery consumption has increased by 50% and its drain from 100% to 50% by 5 hrs time even if you are not engaged into
    any conversation.
2. The applications become real slow, the screen froze very often.
3. No real multitasking is possible now, internet browsing in 3G too is very sad, forget about 2G.
4. Wi Fi data transfer is drinking battery.
5. Phone Dial Pad responds at least after 7 seconds from touch to choose about calling sim option, and calles often frozed
    on screen.
6. Switching between Data SIM option in duel SIM Option is realy sad, it takes 1.5 minutes to get the option activated.
7. Camera is not as usual like before quality is detoriated.
The above problems were not occured during phone used with Kit Kat OS, please give option to go back to Kit Kat, no other help is required at least if you want to keep loyel customers like us. We have paid amount close to Rs. 24000/- and unable to use it, just imagine how disapointed we can be. At least provide the option to switchback to Kit Kat OS through your Sony Service Points, if not posible online.
Regards,
Santanu Sengupta.
praveen_gerela
Extreme hang problem in Xperia T2 Ultra Dual after Lollipop Update.
Extreme and Irritating hang problem occurs after I have updated T2 Ultra Dual Phone with Lollipop Version.
Kindly assist and also if Boot the device will it be solved via flashboot and unlock the bootloader??
Waiting for revert.
Kindly revert.
Thommo
Flashmode or Fastboot mode is only for those that wish to root and install a custom Rom or firmware, if that's what you want to do then head over to XDA - Howwever have you tried a system repair as this usualy fixes issues after an upgrade.
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Robert-K
for lagging problems a factory reset helped for me ... after resetting the phone and installinf all my apps again the T2 Ultra Dual is working normal again
BR
Robert
Sunnyron
My phones ear speaker is getting stopped suddenly for few hours
s4alon
Am I the only one experiencing lag oftenly. Especially when using chrome. @.@
xavinux
Enthusiast
Hi @Sunnyron @s4alon
I suggest you to first run a backup of the device information like this:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
Try performing a system repair using PC Companion:
http://support.sonymobile.com/gb/tools/pc-companion/
This will factory reset your phone and erase all data. You might need tocharge your device for about 1-2 hours before so the device has at least 80% battery. Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device). Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP.
I hope can be useful.
I'm at disposal for any question.
Best Regards,
Amans
I contacted them... And I have gone through All the procedures the told me. software repairing !!! I have done that 3 times... but still my phone works fine in safe mode. There is no  issue withh the sensors and all while using in safe mode.
