This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Hi
I'm updated my Sony T2 Ultra to 5.0.2 Lolipop
After updated the phone response is very slow
KSwapd0 use high amount of CPU
Applications start very slowly
Redraw is very slow
I get a new call, the phone ringing but not show how call me. need 10-20 seconds to display the caller
I've got no sound when playing music on walkman app.
Is there anyone has some issue like mine?
Hi Just Uncheck Adaptive Brightness check box u can get full brightness
settings>Display>Adaptive Brighteness
@anthonykitmcinnis wrote:One of the reasons I loved my T2 Ultra is due to the 639 nits of brightness.
After having updated to Lollipop via Sony PC Companion the screen bright is way low. I went into settings and placed it at full max brightness like I have always had it set and its just not the same anymore.
Its currently the same brightness of my broken Z Ultra.
I hope ths gets fixed or I will have to move on to a different phone.
I am having same problem with mobile speakers and headsets as well and music player suddnly stops some time.and secondly batter is drainis so fast even after using stamina mode.
Im facing several Problems in my SONY T2 ULTRA DUALevenafter the second update 19.3.A.0.472...i list out some of them
1. Can't set ringtone for second sim through any means....only vibrating. For first sim only through Music player
2. CALL feature is very slow...
3. In Chrome new tab doesn't open
4. Video, Whats new update could not Install
5. Phone Lags overall most of the time.
