Xperia T - No Signal / Reception
energylevels
Seem to hve been sold a faulty Xperia T - I have tried three different sims in it and get no signal at all in my house if I go outside it appears to pick up a weal signal sometimes but it's on and off we've never have signal problems in the house before usually 2-3 bars on different networks so unless this phone has the wprst reception ever  I'm guessing this phone needs to be returned or sent to Sony Repair Centre ???  Crying_Face
Johan
Master
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
2 REPLIES 2
Johan
Master
Sachinda21
There is no solution with sony and anyone. ever i have one T3. i have tried so many things to get signal in my mobile but there is no solution.
If any one had please share with us.
