Hello I need help, I got an Xperia SP c5306 from Telcel, the problem is that when I try to use the apps, the app close by itself,
settings, walkman, movies,album, calculator, ALL the apps I can't use the phone and before you tell me repair the software with PC Companion or SUS I did it like ten times and the problem persist I just got a notification saying "bug report failed no new crash data in dropbox", I was testing all the process that fail constantly and I see this:
com.process.media
com.process.acore
sometimes this:
unfortunately storage capability has stopped
I'm thinking that maybe is the bootloader because I update/repair the phone many times or maybe is a hardware problem
what can I do?
I suggest you visit a nearby sony service.
http://www.sonymobile.com/global-en/support/contact-us/
Well I can't change any settings because settings close randomly and root no
