i had wrongly restart my phone xperia sola while the reset is going on and now i cant turn on my phone wat can i do?
repair your phone with SUS
Update Service (SUS)
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
k i'll try
i already hv a backup on my sdcard
let us know how it goes when you repair it with SUS
tat sus nvr detect my phone the same thing going on
cannot detect my phone
wat should i do
is your phone off?
have you unlocked your bootloader?
is the battery at least at 50%?
ok now the (SUS) detected my phone and installing software green led light is going on....nxt wat should i do
