Xperia S speaker not working
SilenceWhisper
HELP.. My Xperia S speaker not working. But when I plug in headset I can hear music from the headset. Running 4.0.4 android..tried software repair but not working
15 REPLIES 15
profile.country.RO.title
_alexdon_
I hope it will stay like this.
alexdon
SilenceWhisper
Hi .. It happens again...
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
If the above does not help, you should stop by a sony service.
alexdon
SilenceWhisper
I tried Software repair before .. Not working. Well I force stop the sound enhancement and smart connect.. Restart phone. The speaker working again. Why is happening huh
_alexdon_
Have the device examined at a sony service.
alexdon
SilenceWhisper
Ok
