xperia p sms tone problem
s9
I am using xperia p & jelly bean last 6 months without any problem. But now I m facing a problem.i don't always get the sms notification tone (fb notification is ok).though other tone & vibration is still working. I check the setting & it is ok. So I restore the setting. Then I notice that everything is ok but after 2days the problem is again noticed.what can I do now??
jackxperiaP
its a bug .. disable your default notification sound to silent then all your tones will ring withoug problem ..
15 REPLIES 15
s9
adding some info to the previous comment. my android version 4.1.2 build number is 6.2.A.1.100.
jackxperiaP
s9
It is solved. When will we get next update?? I live in bangladesh.
jackxperiaP
we wont get major update like 4.2, 4.3 or 4.4 but may get a bug fix update only !!
profile.country.RO.title
_alexdon_
Yes,I support the idea of a bug fix update,but no 4.2 or 4.3.
alexdon
s9
In addition to the previous question, the problem was solved after changing the default notifiaction tone to silent. But I am facing the problem again.what can I do??
_alexdon_
Did you repair phone software?
alexdon
s9
No,I didn't repair my phone.after facing the problem, I reset & factory reset my phone. But it didn't work. Then I wrote in this forum. They suggest me to disable the default notifiaction tone to silent. But now I am facing the same problem. What should I do??
_alexdon_
Are you using Viber or whatsapp?
alexdon
