Xperia P dropped in water :'(
mazahir00
please guys help me. i just droped my Xperia P in water... plz help me what should i do now Slightly_frowning_Face
i turned it off quickly after picking... its about one hour ago this happend to me Slightly_frowning_Face
please help me i dont have money to buy it again Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face
20 REPLIES 20
remove the SIM card and SD card > get a plastic bag and fill it with raw rice and let it dry for 24 - 48 hours, replace the rice every few hours
mazahir00
bro what if i dont have rice at this time... :'( coz m in my hostel and its imposible now to get the rice Slightly_frowning_Face plz any other way... i have removed my sim card and turned it off ,,,
mazahir00
m gonna keep it off for 48 hours and will let it dry in the sunlight... lets see what happed Slightly_frowning_Face
do pray for my phone Slightly_frowning_Face
Blazekick
i would suggest uliwooly's advice as well! and try using a dryer it will get the water dried as well!
mazahir00
should i directly turn on my cell after keeping it off for 48 hours... or should i put it to charging first?
casimirfunk
Please do tell us what happen next. Hope your phone will be fixed right away Slightly_smiling_Face
mazahir00
i'm so much worried.. coz when it was dropped and i picked it up the secreen was blinking lil bit Slightly_frowning_Face lets hope for good... i,ll post about wat happened with my phone Winking_Face
mazahir00
