@Krish310594 - Then you would be best to contact your lcoal Xperia care team for assistance in arranging an assessment of your device.
Hey Guys,
I've been using my Xperia P from last 1.3 yrs. I was also facing battery drain problem like any other user of xperia P. I'm constanly looking for any solution from this forum. but nothing helped.
When I woke up this morning, I noticed my mobile battery has become fat and it stretched the screen out of phone assembly (like curve) :-(.
Please suggest what should I do?. My phone warranty got expired 2 months ago. Do I need to replace my battery.
My phone uses: Li-Polymer batterry * 3.7 V - 4.2 V
1265m Ah battery
Can I replace the battery with 1305 mAh?
What is best solution?
take your phone to the nearest SONY service center. a lot many Xperia P's have had the battery bulging issue. i suggest you get it checked.
