Hello, I've got my new Xperia Ion phone.
The interesting thing that i've noticed that really bothers me that when my battery power reduces to 20% of power it drops to 1% after few minutes.
After that the phone shuts down.
I couldn't find any setting in my phone that do that, so I believe the reason is not the settings.
Did anyone experienced such thing and can help me to solve this issue?
Vlad.
same problem for my xperia ion. i bought before 1 week nly. battery dorps 45% to 1% and shutdowning. plz help. i really disappointed wid sony ion
Dude, please read all posts, the answer for your problem was posted earlier.
yes dude. i try all. but not work out. plz help
i have the same problem too!bt mine one is more worst than u.my one juz brought for a month and it shutting down whn the battery is 70%.pls help me!!
Dude, did you try to shut down baterry save mode? If not read my post on the first page where I explaned how to do that. This might help.
i had read all of ur post,bt it dint work.u said wanna replace another new battery,bt tis hp i juz brought for 1 month ago,hw cn i replace it soon.abt the powersaver,i had follow wat u had said,bt it dint work out too..><</p>
just do this,i've fixed it maybe
For those of you who had the Sony X10, you knew that there was a battery calibration method. I won't go into detail about how it worked, but this is very similar so X10 users should be familiar.
Here's how it works:
Step 1: Charge battery to 100%
Step 2: While phone is still plugged into charger, hard reset phone (volume up + power)
Step 3: When phone turns off, unplug charger
Step 4: Turn on phone (Note: If calibration is needed, battery percentage will be less than 100%!)
Step 5: Plug in charger and charge to 100%
Step 6: Repeat until battery percentage is 100 upon restart.
WARNING: THIS IS UNTESTED. I AM NOT RESPONSIBLE FOR ANY DAMAGE THAT OCCURS TO YOUR DEVICE.
Your battery percentage should increase incrementally with each restart. Example: if on first restart, your battery reads 94%, then it should read 95 or 96% on the next restart.
Please test and report back. After doing this twice my battery life seems much better (currently down to 57% on 8.5hrs of moderate use). Today is the first day, so I'm not sure if it's just an anomaly. Any feedback is appreciated!
Sony Ion - Rom: LT28H 4.0.4 ICS BABY! - Kernel: Stock (waiting for DEVs )
Samsung Captivate - Rom: ICSSGS 4.0.3 - Kernel Semaphore 1.0.0
Sony Ericsson X10 - Rom: Oodie Prime - Kernel: Oodie's FXPMod
finally i got solution for my xperia ion. Download Du Battery Saver Pro apps. its working. try it n tel me.finally happy after installed that apps
i have the same batter dropping issue to 1% ..did turning off the built-in power saver fixed your battery drainage ?
yes 100% sloved. try n see and reply me...
