I have had my xperia arc s for quite a long time but it has always been working perfectly fine.. Just a couple of days ago it was working perfectly and then i tried to play music and when i opened the music app, it just freezes and it says "Music is not responding. Would you like to close it?" I have factory restored the phone and reset the customisation and probably everything there is to do... I cannot access the "downloads" app/folder so when i download something from internet or the app store, it just freezes and will not download. If i go on youtube, i cannot watch a video. Also whenever i try and open camera it says Error, camera not available... It says i have the latest software and i dont know what to do in order to fix this, please help.
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If that fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
YESSS! Im so happy now, thank you so much i used pc companion and it works now, every single thing works :))))) #Lifesaver
Glad you got it sorted
