hi,,
i am unable to put different wallpapers for lockscreen and homescreen on my xperia sp.If i try to change a lockscreen wallpaper, it does not get changed but keeps on showing the same wallpaper as homescreen wallpaper.If i change homescreen wallpaper,it gets applied to lockscreen as well.Can't we have different wallpapers for home and lockscreen?kindly suggest how to fix this.thnx in advance.
you can only have a different wallpaper on the lock screen if you have swype lock, if you have pin, password, pattern etc you can not.
here are some alternatives
WidgetLocker
ICS Lockscreen HD
Lucent Lock Screen
Extended Controls
https://play.google.com/store/apps/details?id=com.extendedcontrols&feature=related_apps#?
