Wallpaper issue.
Edison1
Wallpaper issue.
Good evening people!
I am glad that I got my Xperia S today and im totally in love with it, but there seem to be an issue with the wallpaper resolution.
The problem is:
When ever i set ANY pictures even the wallpapers that it came, it doesnt do a full size fit on the screen. Its nearly like top and bottom been cut off.
As you can see, that white background is the stock background and it is not filling the space. :l
So i back tracked myself from the first thing i got my phone till now. I realized it wasnt like this few hours ago. Instead, it was after I restored the things from my previous phone ( Xperia Arc S ).
Therefore I believe when the phone asked me to restore the previous stuff from before it somehow changed the resolution settings on my Xperia S.
My question is... is there any way to resolve this issue? rather than restoring the entire phone? I kinda just did all the installation and moving and all. -.-
thanks in advance.
Edison
Edison1
Never I solved it myself.
Go back to themes and change it to anything else other than the current theme you are currently in. and then go back to that theme and its fixed.
2 REPLIES 2
Edison1
cvalverde
Hello Edison, hope you can help me.
The problem that I am having is any picture that I try to set as wallpaper looks good couple of hours after that the picture turn a full size without reason on the wallpaper
