Dear Team
My system canot proerly woring
Unfortunately, Xperia Home has stopped Working
Regards
suresh Kharat
I just wanted to reply that this worked for me. I recently got a Sony Xperia Z3. Tonight, for some reason, it would not respond after charging. In the upper left crorner where normally it was a green LED or flashing blue LED, I had a yellow LED light. The phone would not respond. I could restart it by holding down power & volume, but I would loop on the error that Xperia Home stopped working.
I swiped down from the notification bar and went to Settings, Apps, All, Xperia Home and cleared the data. I had to restart and my phone is responsive again. I think it had to do with a theme I downloaded. I had the Miles Davis Kind of Blue theme installed. Anyways, I am going back to stock desktop for now because I cannot afford to lose my phone's functionality.
It's only been a month that I've had this phone and I've loved it so far. I'd hate to have an issue with it now.
EDIT: I see this is an Experia J support forum but it was the first response on google when I queried "sony z3 xperia home has stopped" so maybe it will help others in the future.
Just got the new sony 2 days ago...
has aparently stopped working, plugged it in , restarted etc etc.
kinda upset thought things were up to fluency with Apple..
Maybe I should switch back..?
I have a Z3 that suddenly stopped working tonight.
It just says "unfortunately Xperia Home stopped" and "unfortunately email stopped". I can not access anything and I get the same messages in Safe Mode.
It is not possible to access anything, if I try to swipe from notification board and use quick settings the phone freeze and goes off.
I can swipe in my pattern and I instantly get a blinking message as stated above.
I have not added any apps lately and my phone are not used for internet purposes much. So the advices stated in this article does not work on my phone.
No, i can not take a screen shot, because, phone is frozen
The phone has never been dropped and has a cover on as well
Sorry to hear that.
One thing you can try if your phone has internet is to download and install another launcher. To do that, go to play.google.com using a computer, logon with your Google account, select a launcher, click Install and then select your phone. You can for example try this launcher: https://play.google.com/store/apps/details?id=com.teslacoilsw.launcher
Wait a few minutes so that the phone has time to download and install the app (this is done automatically if it's connected to the internet) and then restart the phone. When it starts it should ask if you want to use Xperia Home or Nova Launcher. Select Nova Launcher and then see if you can access Settings and clear data for Xperia Home. Then you can switch back to Xperia Home under Settings -> Home.
If this doesn't help i recommend that you perform a repair of the phones software using a computer. You can download software for this from http://support.sonymobile.com/global-en/xperiaz3/software/.
My phone had this same error. (Experia Z1)
i did the same sequence above and it work!
I am having the similar kind of problem, googled many options but none seems to be applied in my case as I am continously getting popups, and can't select any settings or any other option.
I don't have backup of my updated contact list unfortunately so don't want to reset the phone right now.
But it is totally unusable now, after getting the popups for some times, phone gets hanged.
Please suggest if there is any solution.
Thanks.. Its worked...
I want to know the reason.. Can you explain?
xpiria has stopped
I have the same problem. I tried clearing data and cache for the xperia home on the app setting, but that did not help
