Unfortunately, Overheat Control Has Stopped
BabyLollie
I updated my phone yesterday. It worked fine. I used it till the battery ran up. But when I charged it, and restarted it after that, the message "Unfortunately, Overheat Control Has Stopped" pops out.  When I press OK, it pops out again in less than one second. Restarting the phone does not help.
Is there any way to fix this problem?
Thanks.
Wei Zhe.
what happen if you try to use SUS?
9 REPLIES 9
BabyLollie
Hi what is PCC? And my phone is completely dead now as I can't use any function on it with the message" Unfortunately, Overheat control has stopped" message popping out every second.
PCC = PC Companion
SUS = Sony Update Service
did you unlocked the bootloader? rooted your phone? dropped? water damage?
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
RELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
BabyLollie
I did none of the above. It just happened suddenly and I don't know why.
BabyLollie
IT WORKS :smileygrin:
BabyLollie
Thanks man :smileygrin:
Excellent Slightly_smiling_Face
Devani
Im having this problem any help? ... And SUS doesnt work anymore
