Please Let me Know This Charger is Compatible with T2 Ultra Dual Or Not
USB AC Adaptor
Model:CP-AD2
Specifications of Charger
Dimensions Approx. 41 (W) x 61 (H)x 26 (D) mm (Main body)
Weight Approx. 53g
Supplied Accessories Micro USB Cable
Output Voltage(V) 5V
Output Current(A) 2.1A
Yes, you can use that charger.
does this will damage my phone battery, due to high output 2.1 AMP
My phones stock charger is 1Amp Output
What's important is the voltage. The charger must be 5.0V.
The amperage is how much power the charger can deliver.
Thanx For Valueable Information
will the 2.1amp charger help in getting the phone charged quickly than the 1amp charger?
You will probably not see any difference in how long it takes to charge the battery with a 2.1A charger. Charging the battery from 0 to 100% takes about 3h and 20min. but any usage of the phone while it's charging may affect the time it takes to charge.
I am buying 2.5Amp Fast charger.. Shall I purchase it?Will that affect my Sony t2 ultra?
